OMC cobra 3.0 Overheating
Jessfly1
I just bought a 1991 VIP with a 3.0 omc cobra I/O. Had it out on the lake once and it seemed to over heat a little but nothing to bad ( Just over half way on the temp gauge ). I took it out the next weekend and it overheated ( buried the gauge ) to the point of detonation. I did not like to push it but it was sort of an emergency situation. After killing the ignition the motor was still running and i had to choke it out. The guy i just bought it from said he replaced the impeller the beginning of this season. I have been in mechanics almost my whole life but im sort of new to this boat thing. Is there any know issues with these motors overheating? Any guidance would be greatly appreciated. Thanks.
mkast
Re: OMC cobra 3.0 Overheating
Have you ever started the engine without water to the sterndrive?
Jessfly1
No its always had muffs or been in the lake.
sea wolf
Have u looked at the impeller? How do u know that the p.o. didn't run it dry? Most overheat issues can be traced to a bad impeller.
Jessfly1
The p.o. said he replace the impeller the start of this season but upon further investigation i discovered the impeller is screwed. Is it a good idea to back flush the cooling sys. if half the fins on the impeller are missing?
Jessfly1
Another question, where does the water get exhausted from? I know where the inlets on the stern are but i don't see any indication as to where the used water gets expelled.
sea wolf
If u don't find the pieces, it will overheat due to a blockage. The pieces may be in the hose from the transom to the t-stat housing.
