hijinks1951
- Joined
- Jun 17, 2007
- 15
so boat was given a tune up and then run once or twice before being winterized and stored for 18 months. Started on second try to move to ramp for trailer. Relocated it and took it out, ran ok except it would not start easily after planing for 20 mins and WOT was only 3600 RPM (never got more than that when I bought the boat and thought is was prop pitch). Noticed water coming from the valve cover breathers and oil inside valve covers was milky. Crankcase oil looks ok. Disconected breather tubes from flame arrestor and boat started better after being run probably because water was not going into carb. Replaced exhaust mainifolds and risers but still the same, replaced intake manifold gasket and reduced water flow from valve breathers considerably but not completely but now WOT is only 3000 RPM and boat won't plane. Set dwell per specs and used timing light to adjust timing, BUT it seems way advanced in order to get the engine to start/run smoothly.
