I have been through just about all of the posts regarding shifting and adjustments. I have a new cable on one engine that I just installed and followed the procedures.<br /><br />The problem is, both engines shift to reverse hard, especially when trying to maneuver. If I'm backing out of the slip, it goes in fine. It seems to be after being in FWD first, or while shifting back-n-forth to maneuver the boat only. Does this make sense to anyone.<br /><br />Also note that, I manually checked the ESA. The ESA on my STBD engine appears to work, and that side seems to have the hard shifting issue MORE than the PORT side, which the ESA does NOT appear to be functioning.<br /><br />I really want to fix the problem, but it's hard when it doesnt make sense.<br /><br />Any help, suggestions (I have read and followed the hasings stuff and I have several manuals).<br /><br />I did read a post about good points and dist. cap. Could this have anything to do with it.. I know the points/caps have not been done in at least 3 years.<br /><br />Engines run great, the timing is on, just the hard R shift issue..<br /><br />-Dave
