ab59
Ensign
- Joined
- May 10, 2017
- 991
unclear about OMC 5.7 engine alignment
I have just set the engine back in the boat and got the front mount bolts started but not tight. Although I have watched many several videos on this I'm not clear on what needs to be done. I have the engine alignment tool and when inserted and removed leaves pretty much an even spline marks around the end of the tool but it is not in the middle of the gimble but off the the bottom. Also , the tool is not easy to insert or remove . The videos all say if the spline marks are even then it is correctly aligned but it seems to me that the tool should also be in the center of the gimble when correctly lined up and easy to insert and remove as well. Aren't all three positions and conditions necessary fo correct alignment or is the even spline marks the only requirement ?
