OMC Cobra Drive Problem
Lou C
Re: OMC Cobra Drive Problem
I'd do some more checking before I dumped the OMC. For one thing, with the drive off, the bellcrank on the right side of the pivot housing can get deposits built up behind it and that can cause it not to shift right. The transom shift cable has to have free movement and you need to use the 2 tools sold by either OMC (can get them from Crowley Marine) or Midnight Wolf on the forum. Midnight Wolf also has the needed parts of the shop manual on his website to set the cables up right. Make sure you are looking at the right ones for your model. Some have the slot for the remote cable on the bottom of the engine shift lever, some like mine have that slot at the top. There is also an OMC service bulletin that nicely summarizes the 5 steps needed to adjust it.
First you have to make sure the bellcrank moves free and easy and the cable does not have excessive drag (like not more than 2 lbs measured with a fish scale foward n reverse full travel). Then you have to use the special tool to hold the bellcrank at 90* and use the other tool to set the cable adjustment. Next you re-attach and tighten the cable retainer. That's for the transom cable, the cable from the remote control to the shift bracket/bellcrank on the engine bracket also has to be adjusted. Both have to be in proper adjustment for it to shift right. And also, the shift rod in the lower unit must be set right for height. That should be checked first actually. What all the adjusting is trying to accomplish, is to get the neutral position properly set with the cables and to get the same shift stroke in fwd and rev. That is what will ensure that both fwd and rev fully engage the clutch dog. If its jumping out of gear, its not engaging the clutch dog and it will wear it out in short order. You need proper throw both from the remote cable from the shift/throttle control and from the transom shift cable.
It all takes time the first time you do it. It is necessary to have a helper rotate the prop to check to see if the clutch dogs are completely engaging when you shift to fwd and rev. You should not shift it unless someone is rotating the prop.
If the transom cable is stiff thats your problem right there. That has to have very light drag.
You also want the engine idle as low as you can get it without stalling.
adchrome
UPDATE..
Gears and clutch dog toast....putting in a new shift cable too....$1446 to fix...uggg
adchrome
didn't really have $1500 to spend let alone $2500
Idlespeedonly
I understand. But the sei warranty is a nice feature to have.
adchrome
yea i wish i could have gone that route but just can't right now....
what can i do as far as maintenance to keep from chewing gears up again....?
Idlespeedonly
Keep the cable adjusted, good clean oil and quick and firm shifts going into gear.
Good luck with it!
Lou C
Keep BOTH cables adjusted, not just the transom shift cable (engine bracket to the drive) but also the remote control cable (remote control to the engine bracket) can get out of adjustment (adjusted at the bellcrank on the engine, slotted part of belcrank) and cause shifting problems.
When you set up the transom shift cable measure the drag 2 lbs or less with a fish scale
Make sure the bellcrank in the pivot housing does not have deposits crudded up behind it, if so clean em all out, work the shift control back n forth and pack that whole area with OMC triple guard grease
When you re-install the drive, coat that gasket very well with OMC gasket sealer and coat the sealing surfaces on the drive and pivot too, that helps keep water out
Get your engine in good enough tune to idle reliably at 550 rpm in gear in the water.
I've run mine for 10 years in salt water, the cable was set up initially by a good mechanic and it was fine for a long time, I had to re-adjust it because the remote cable end moved in the slotted part of the engine bellcrank. So I did the whole thing, set the shift lever height in the drive, transom cable, remote cable. Shifts like a new boat. I am not so sold on the SEI conversion. I'd have to see how well the adaptation from OMC to Merc actually works before I put money down. The idea is very clever for sure, but I'd like to try one first. If my clutch dog went I'd just get it re-done. I like the Cobra when adjusted right they shift great, with almost no effort. If you have the right tools and read the instructions several times it is not that hard. And then you have a skill few marine mechanics have. Keep in mind also that the Cobra has some other plusses, for one the water pump in the drive is very easy to change and the bellows is much easier to change to as compared to the Merc Alpha.
adchrome
thanks...I don't have much luck fixing stuff these days, I took it to a Real OMC Mechanic after the prop hub fiasco, (long story there)
did some homework on mechanics around here and these guys seem good, super busy shop, Costly but what ya gonna do..
