Omc cobra sterndrive question.
Ducatinut
That's a lot of slop. It's been a while since I was deep into a Cobra, but I'd make sure the rear carrier bearing is set right. If I remember correctly, there's a threaded ring that needs to be set right or you'll get binding or slop in the propshaft.
Yarecky3
I check a diagram again and I don't remember 2 retainer rings. Itrs 88 four wins so there should be two of them just behind forward gear.
Anyway I'll take it out again.
Thx for confirming it's not normal.
Yarecky3
Well. I stripped it down and everything looks ok. No retaining rings on this model. Not even place for it.
Is it possible that this behaviour is normal?
Cheers J
