88 OMC Cobra.
Does anyone know if the electric motor can be removed from the pump assembly without doing all the disassembly of the pump unit that the book shows, prior to removing the motor?
My up tilt is sporatic, I can hear the motor / relay click but from time to time the drive won't lift until after several clicks of the switch. Figure the motor needs cleaned or replaced. Wiring is fine, at least up to the motor.
