OMC ROOKIE
Thread starter- Joined
- Sep 10, 2012
- 5
First time poster. Sorry if this is too long, but I have sat as a silent guest for the past few weeks reading almost all this site has on my 88' omc cobra.
I bought one that would stall out the second she was shifted to reverse: Watching the linkage I noted a lot of slop in the transom shift cable, it was also stiff in the control. Holding it tight and even by the engine side trunion, not allowing the cable to move side to side. Put her just into reverse and the motor stumbled she went straight in to reverse. Perfect I'll just change the cable:
Outdrive came off easy... BUT U joint bellow is full of water. U joint is rusty and not accepting grease. Gimble bearing looks rusty, but is still holding and taking grease. Grabbing the bearing with my finger I felt no slop in any direction, but when spinning the bearing I could feel some rough resistance. So I'm buying the bellow kit with a Gimble Bearing. I also found a used (Supposed 250 hour U Joint) With reportedly no slop and that still accepts grease.
Ok so I'm 100% studied up on all shift cable adjustments and techniques. I've bought the alignment tool and the bell crank alignment tool, and the cable jig. The bell crank has a good size flat spot, I'm going to call that the under lying cause for the cable bind. So I bought a new bell crank, and bell crank bushing.
I will remove the pivot house for better access to bellows, and shift cable, and gimbal bearing.
I'm hoping the water is coming in from the bellow, or gasket, or water inlet, or grease tube??
Any other concerns knowing that water has been causing rust in this area? My splines are all good. I have not checked lower unit oil yet, but that is a separate system?
Does anyone have any pointers for U joint removal? I can't find anything about dismantling. What parts/gaskets have I not considered for u joint installation?
Only a couple of weeks left for Cleveland boaters, I'm hoping Saturday goes smoothly.
