Re: OMC Cobra vs Mercruser keyhole
Thanks. Engine mounts would be the largest thing there, and I just built / installed mine, so I wont be too timid to cut them out and make new ones wherever required.
Is there any kind of table or drawing set on line showing the different mount requirements?
Not really.
What you do is, install the gimbal mount and inner transom plate(which
is the rear eng mounts) ........... and put the engine in with a lift and bolt the flywheel housing mounts to the transom plate mounts.
Then, get the engine in approx alignment.
Left/right and up/down(rear) alignment is basically taken care of with the rear mounts.
Up/down (in the front) is where the front mounts come in.
Holding the engine with the rear mounts and the lift, you locate where the front mounting pads will need to be (with the front mounts approx in the middle of their adjustment)
Once you have the pads/stringer/blocks etc all glassed in the right place and the right height, you can rest the engine (front mounts) on the pads to locate where you will need to drill the holes for the lag-bolts. Everything is based on where the engine will sit once aligned.
Then when you get it all bolted down and tight, you'll do another final alignment (using the alignment tool)
