Re: omc crankshaft journal pitting
By the book, any pit is unacceptable. In the real world, we've seen some tiny pits on a rod journal and the needle bearings were just fine. Hard to say without seeing what you have. In general I'd say that if the rod bearing on that journal has been fine then it'll continue to be fine. If you took the motor apart because of a rod bearing problem on that journal then a different crank is in order.
