OMC electric shifter
Days away
I would like to know if anyone know's where I can buy an electric shifter for a 1977 OMC 235 it has just the single handle control on it now.
or is it possible to put a push button shifter on it or ????????
Thank you.Sherman
zbnutcase
Re: OMC electric shifter
That switch has been obsolete for years..... 'nutcase
Chuckyd973
I have a 74 bayliner with electro shift......I pulled a newer shifter from a junk yard and wired up the electro shifter to a three way switch on the dash. forward position is up, nuetral is in the middle, and reverse is back. In Nuetral I can rev the engine like a car motor.......works great just dont acidentaly hit the switch in the wrong direction while accellorating.
ECVCHAMP
I had one 2 years ago, same problem. After searching the net and ebay I found one up in Washington state but, he knew what he had and wanted $800 each for them(no that's not a typo):mad: So I got on ebay and purchased a twin stick, used the taller one for the throttle and the shorter one I fabed up a bracket to mount a battery switch that was on/off/on(forward/nutral/reverse). and it worked great. Just remember any time you go into gear or out of gear you MUST be at idle.
