OMC engine serial number and HP
kupps
Where is the S/N on a OMC 120/140 engine block?
I found a K and several numbers on the block right above the starter. Will I be able to find out the HP with just the serial number??
Reel Poor
Re: OMC engine serial number and HP
Yes.......Do you know what year it is?
kupps
The boat was built in 1979. So I am assuming the engine is a 1978.
Reel Poor
Your going to need the model number. Then you can look at this link and see what you have. Click on OMC Stern Drives 1964-1993......The model #'s are listed on pages 66 thru 71.
OMC Identification Chart
whywhyzed
Banned
If it has a harmonic balancer on the front of the crank, It's a 3.0L/140HP
If it just has a pulley, it's a 2.5L/120HP
chris cross
hey captain,i also have a 3.0 and wanted to find info on it, so i tried to use that link and only got a blank screen.what might i be doing wrong??
Reel Poor
It's an Adobe file may take a minute to load.
If you have the model # and you know it's a 3.0 Liter there is nothing else in this link to find.
chris cross
thankyou for the info.i found the mod.# but still have no clue on the hp of the motor.its an 88yr 3.0 might you know the hp?
the 2.5l is 120hp........
the 3.0l is 140hp..........
chris cross
thankyou very much sir. its my first boat and i have a lot to learn.have a good one
chris cross
got a question for you bond-o,i have a 16.5ft boat and the floor where the jump seat sits is not very strong.i can stand on it but it is a little soft.will the rott keep moving up the floor or can i put a lot of fiber glass on it to give it strength.
