Hello group,
Need your help please. My 1990 OMC 2.3L has been converted to electronic ignition using a Ford Motorcraft automotive electronic ignition. Now the Electronic Shift Assist (ESA) is inoperative. My boat is idling and shifting at 1400 RPM.
#1-Would it be possible to install the Pertronix circuit listed on Stuart Hastings website to make the ESA work again?
Link: http://www.hastings.org/~stuart/cobra/diodefix.jpg
#2-Will a shift assist switch fix the problem?
Link: http://www.jmsonline.net/OMC-SHIFT-ASSIST-MODULE.htm
#3 Can I try to adjust the carb idle stop and lower the RPM's and not worry about it.
Thank you very much for your help I am at a stopping point. Ed
