gottaboatnow
Thread starter- Joined
- Aug 26, 2010
- 13
So, I managed to complete my swap from 3.8 to 4.3 on my Stringer 800. Everything works perfectly! Well, okay, there is one issue that has come up. The exhaust isn't coming out of the prop hub but is coming out of the intermediate housing where it meets the drive unit. The engine won't start unless you raise the outdrive, then she'll start right up. Lower the drive, and she'll stall right away. I can't seem to find any topics on plugged exhausts for OMC's, so I'm guessing this isn't common? Everything inside should be completely clean, as I was pretty detailed when putting the pieces back together. I cannot figure out what might have stuffed up the exhaust, but when it was running, you could go for about 15-20 minutes before she just suddenly quit. Then, you were dead in the water. I only figured out the raising issue when I was near some rocks and had to pick up the drive to avoid banging into them. Any thoughts from anyone out there? Thanks!
