zarillus
Thread starter- Joined
- Jan 29, 2009
- 252
Kind of a two part question:
Hope someone can help me out, i just replaced the two cables on my 89 evinrude 110hp with standard omc side mount shifter.For some reason my fast idle lever keeps popping up when i shift into forward it also does this in reverse??
I don't know if its related however when i first start the motor i have to manually make sure the idle srew is pressed firmly against the stop.If not the thing starts up and its running at like 3000 rpm until i push the idle screw against the stop.After i have done that and i shift it forward or reverse i cannot get it to hold against the idle stop unless i manually push it there.
Any thoughts??
Any thoughts??
