mckinneyboat
- Joined
- May 24, 2009
- 29
I just filled my omc outdrive with gear oil this evening from the bottom. can anyone tell me if this was wrong. reading my manual it says to fill it from the middle.
It's the "universal method" that destroys a LOT of Cobras each year.......If you should by chance have an OMC Cobra Drive, I have no experience with those other than the above description seems to be somewhat universal between drive brands and types.
I can't say what the 1987 OMC manual says anymore since I sent it to NY along with the drive and some other parts a few months ago.I just looked in my manual, and it states that if you are using an oil pump to fill an empty drive, to use the center hole just below the anti cavitation plate
I don't know what manuel u have, but I have the factory OMC manuel. And nowhere does it say to fill from the bottom plug. I'd like to know how u get oil in that bottom plug without it running back out, if u don't use a pump. Can u tell us the manuel you're using & the page #'s that state what u are saying? To the original poster. You need to drain the oil, & start over again, filling from the middle plug. That's if u want to save your drive.I just looked in my manual, and it states that if you are using an oil pump to fill an empty drive, to use the center hole just below the anti cavitation plate, and the slower the better. because putting oil in too fast can cause air pockets, that, if not burped, can lead to drive failier.
Without an oil pump, it say to use the lowest drain on the bottom of the torpedo, and to go slowly, because putting oil in too fast can cause air pockets, that, if not burped, can lead to drive failier.
Funny thing is, it also say that if you get bubbles, worry not, because you can slowly rotate the driveshaft and work them right out.
Oh, and filling an empty drive is the only time you check the drive oil level with the dipstick completely unscrewed.
Maybe it's not the "universal method" destroying the drives, but just rushing a job, and not verifying how much oil you are actually putting in the drive.
Like I said, run the drive for a few, let it sit, top it off in the morning.
I have filled my 87 OMC cobra from the bottom every year since I got it ten years ago. My boat gets year round daily use as I drive it across the lake to work 5 days a week.
It doesnt matter where you fill your drive from, but how fast you fill it, and more importantly, that you put your 60, 64, or 108 ounces
