alley mechanic
Thread starter- Joined
- Apr 15, 2011
- 100
Hellow all, i have a question about the omc float guage that i just acquired from a friend that had it laying around that he never used,i tried to check with this guage using the v4 v6 cut out but it is not even close to what the spec one thirty second plus or minus one thirty second i set mine just slightley off parallel with gasket surface when you put the guage at the toe of the float it shows the float with carb inverted has to go way down which i know that is not correct do they have different float guages for my 98 115 intruder or am i measureing it with the guage in the wrong place can some one that used this guage give me some information how to use it.
Thank you
alley mechanic
Thank you
alley mechanic
