Re: OMC Flywheel difference
I understand very well what you are saying, I din't even go to the timing check yet, since I believe problem resides in flywheel.<br /><br />The trigger sits inside the 4 posts holding stator armature, and it rotates partially counterclockwise to change timing. With this set up trigger is resting all the way back against post closer to heads of motor, and cannot be moved that direction anymore, I can slide it forward (folowing throttle lever) as much as I want (till next stator post), but the starting point is already way too advanced.<br /><br />I hope I explained situation.<br />Other way around could be installing flywheel in differnt position on crankshaft, but this will include cutting another shear key slot in it (way out of my capabilities and not worth it).<br /><br />The reason I point to flywheel is location of sensors underneath it, if newer ones have sensors positioned slightly different, it will change timing in relation to trigger position.<br />Unfortunately I don't have another V4, I only have a V6 1989 and I rather not mess with it (runs very well).<br /><br />My question was also pointed to anybody that can have both flywheels on bench to look and see if underneath they are different. I am trying not to spend a fortune replacing original ignition parts when I have here some newer and in good conditions.<br /><br />Val
