Rosbullterrier
Thread starter- Joined
- May 21, 2009
- 18
Gentlemen, both Stringer 3.8 OMC's (1981) are installed now, everything in working order.
However, the starboard helm remote lever shifts forward and engages reverse instead of forward and when shifted back it engages forwards - bit awkward for lining up the two throttle controls to go in the same direction!
After much thought, I can't see how altering the helm control lever or the cables/idler pulley in the shift converter housing would change the direction of pull.
However after looking at the service manual pictures of the shift housing in the gearbox, I don't really see how that could have been installed wrongly either. The cable end pucks are different sizes and so not interchangable. I don't want to lift the boat from the water and dismantle the outdrive if that could not be the problem . . .
