drexton311
Thread starter- Joined
- Jul 19, 2016
- 51
I have been all over the internets and have not found exactly what I am looking for. I hope you can help. There seems to be a lot of info on the Alpha drives but not the Cobra drives.
I have a 1988 OMC Cobra with Chevy 5.0 and 2bbl carb. Model# 502APRGDP
I purchased the Sierra 18-2771 which contains:
18-2613 Outdrive Gasket Set
18-2765 U-Joint Bellows, replaces O.E.# 983973, 987467
18-2764 Exhaust Bellows, replaces O.E.# 914036
18-2763 Shift Cable Bellows, replaces O.E.# 911826
18-2100 Gimball Bearing, replaces O.E.# 983937
18-7315 Hose Clamp
1. What is the P/N for the grease/oil seal that installs before the gimbal bearing? - I cannot find this P/N anywhere and the iBoats schematics have the part pictured but not identified as a seal. Anyone have any idea?
2. Can I replace the bellows without removing the pivoting portion of the Transom/Stern assembly? I do not want to mess with adjusting the cable that I would have to disconnect if I remove it as instructed buy the OEM Manual. If I can, what are the chances of damaging the cable? I am worried about not setting the cable correctly as I have heard horror stories and currently the boat shifts flawlessly.
3. I'm deciding if I want to replace the u-joints at this time as I am not sure how old they are. (same reason I want to replace the gimbal bearing) I have no experience with u-joints, what is the best way to replace them and is there a "cheaper" alternative to using the marine joints. can I use auto, does anyone have a P/N?
Thanks all!
18-7315 Hose Clamp
Thanks all!
