Omc hydraulic trim oil
Nick2020
I have a omc stringer with a 5.7 omc. In the process of changing the engine I removed hydraulic lines from the trim motor and a bunch of oil came out. Is there a way to refill it and what oil would I use?
froggy1150
Ensign
What i did is take a bolt that matches the screw threads, drill a decent size hole thru the center, cut the head off and add a nut w/gasket. Then i hoseclamped a rubber hose to that and a funnel. Hung the funnel and put some hydraulic fluid in and let it burp. Then cycled up n down. Peat...peat...n repeat til it goes all the way up and down. With rams extended remove fitting and let extra drain out. I used aw46 hydraulic oil but trim fluid or power steering fluid should work.
