finnaddict98
- Joined
- Aug 23, 2001
- 22
Changed out the prop shaft seal..actually went MUCH better than expected. BUT I noticed that the lube was milky and proceded to change it......it is so "goopy" that its taking forever to drain out. It is still slick and slippery as all get out. Another BIG problem is that there was water draining out at the same time. Is there any way to fully evacuate the lower unit? Is there a lower unit flush and fill kit?? My current plan is to drain as much as possible, refill, run it a bit and drain and re-fill. Ill keep doing this until the "yuck" clears up and I get decent looking lube draining out. FYI- I overtightened the prop and burnt the prop shaft seal...when I removed the prop the only thing left was the round (or at least used to be round) spring O-ring. So Im confident that the water was entering from this blown seal.... When I did my first drain, refill, drain the lower drain plug shot out under pressure as I unscrewed it and alot of thick milky lube SHOT out. Should I continue this practice or just take it to the shop and be done with it??? Any and all suggestions are welcomed....Thanksnull
