me and capri
Thread starter- Joined
- Jun 5, 2010
- 12
I have a problem with my 85 omc full mechanical 400 not shifting into gear. I removed the cables from the converter and tried to manually pull the cables into gear. In either direction I can turn the prop manually ,but I do hear it in the bottom case. In neutral position ,no sound at all. Also when running nothing happens. Should the drive lock up when I put it in gear by hand? The cable measures out @ 8 inches pulled out and 6.75 inches pulled in. That is from the end of the cable housing to the end of the round keeper. Just can't get it to go into gear. It is a 85' 3.0ltr Capri. Any help from some more knowledgeable than me would greatly help. Is my shifter cable hooped? HELP. I need to be on the water again. lol
