OMC REMOTE 1992
NOSLEEP
HELP <br />The tilt/trim switch on my remote throttle handle is loose, pushes into handle when used.<br />I have studied it carefully, removed cover around controll body but cant seem to figure out how to get into the handle to tighten it up.? <br />1992 OMC REMOTE FOR EVINRUDE V/4
rickdb1boat
Re: OMC REMOTE 1992
You need to remove the handle itself, if you did not do so. You will find the screws to tighten it, once you have it off.
NOSLEEP
Re: OMC REMOTE 1992
Rick<br />I will have a closer look and see if i cant get the handle off.<br /> thanx for the reply :)
NOSLEEP
Re: OMC REMOTE 1992
rickdb1boat<br /><br />I went back into the remote last night<br />there is an allen key bolt on the inside<br />of the handle at the back of the remote<br />it looks like it might hold the handle on<br />or may be just the metal hub<br />with a star like inner spoke (key) sort of<br />thing . how does this piece come off .Do <br />you need a special tool. or am i going about it wrong.I have the allen key bolt out and the cover off, the tensioner off ?
rickdb1boat
Re: OMC REMOTE 1992
No Sleep,<br />Lay the control unit down on it's side and place 2 blocks of wood under both sides of the control handle to support it.(2 X 4 pieces will work) (This is done with the remote control unit still together).<br />Loosen up the Hex Screw in the center of the control lever 3 turns. Take a center punch and place it in the center of the now loosened Hex head screw. Give it a few small raps with a hammer and the handle should pop free of the splines. Remove the screw all the way and remove the handle.<br /><br />EDIT: You should still be able to do this with the cover partially apart. Just put the allen screw back in until it bottoms out and then back it out 3 turns and follow instructions above.
JHH
Re: OMC REMOTE 1992
Don't remove the allen screw completely, but rather, back it out about 3/4 of the way. Then gently tap the screw head with a screwdriver to drive the handle off the other side. Then remove allen screw completely.<br /><br />Good luck.
NOSLEEP
Re: OMC REMOTE 1992
Thank you gentleman<br />I will follow instructions tonight ! :)
NOSLEEP
Re: OMC REMOTE 1992
Gentleman <br />thank you for all the help. fixed my remote <br />tilt/trim . got the handle of no problem<br />friday night. Just like new now!<br /><br />MERRY CHRISTMAS & GOD BLESS :)
