jmarine225
Thread starter- Joined
- Jul 13, 2009
- 95
I have a 93 Four winns Vista with an omc 5.8. I went through all the trouble shooting for overheat issues and am still running hotter than normal as I cannot touch the risers for long when the engine is running--showing temps around 180 and have a 160 t-stat. It appears the original exhaust manifolds are on the engine and one of the risers is original. The boat has been used in brackage-brine water also. I am looking to replace the risers to see if that helps with temp. I reviewed the manual and it appears to be an easy job, removing 4 bolts and the exhaust hose. My question is can I complete the riser replacement while the boat is still on the water? I can't see why not since water doesn't come up that high and I have no water in my oil. Please help ASAP as I'm looking to replace these this weekend. Thanks.
