OMC running Temp
notinbig
I know it is still really cold water but my 88 larson never comes off of cold, problem or not running cold?
Boatin Bob
Re: OMC running Temp
It's not good to run cold, you don't get proper combustion, I would suspect a stuck open t-stat or possibly a faulty temp guage/sender. Do the risers get hot?
I had a the same problem with my 2.3 omc. The boat is 15 yrs. old, and I bought it from my uncle. He said it always has run cold (guage never moved), and He also said he never changed the outdrive impeller. To make a long story short when I took the old impeller out to the parts house.They looked up the numbers, and the impeller was for a v8 engine. The right impeller was 1/2 the thickness. The bigger one caused too much water to come up to the engine, and the thermostat never opened. My temp is fine now. Either my uncles memory is no good, or it came that way from the factory. Just an idea to check.
Cobra SX
Ya im haveing a problem with it staying on the Left side(gauge doesnt move). the risers on the boat get fairly warm , but not hot. <br /><br />I have never changed my T-stat. when i turn the ingtion on to off the gauge does show movement.<br />But never while running will it even move.<br /><br />I have a 302 V-8 OMC sx
