OMC Sealant, Moly Lube, Adhesive and Grease Equivalents ?
mpritch272
I'll be pulling the lower unit to replace the water pump in a 2002 Johnson 90 motor (J90PLSNF, 60 degree V4 loop-charged) this weekend, and the Clymer book references:
OMC Adhesive M Sealant
OMC Moly Lube
OMC Triple Guard Grease
OMC Gasket Sealing Compound
Is it essential to purchase exact items, or are there other equivalent options available?
Thank you.
Pritch-
BoatBuoy
Re: OMC Sealant, Moly Lube, Adhesive and Grease Equivalents ?
Also available at ishopmarine.com. PN 508298(8 oz.) and P/N 775776 (14 oz cartridge). Your local JohnnyRude dealer should be able to get it. However, I've been using Lubramatic Marine with good results.
USBoatsupply.com, the website referenced by the Evinrude site, appears to be offline for maintenance.
