sirproteus
- Joined
- Jul 18, 2004
- 1
I have a 4.3 omc cobra (GM- v6.) I removed the starter as it was draggingand found the brush springs had failed. I replaced them after a couple of weeks searching. I hooked it back up and am just getting a click from the top side of the motor, I assume the solenoid. I am concerned that the two smaller wires may not be connected properly. I have learned my lesson on taking notes when removing things but that does not solve my problem. The larger wires can only go on the main larger post on the starter. Additionally there are two other wires. One grey and black (mainly grey), one yellow and red mainly yellow.) Looking at the back of the starter the larger main pole is in the middle, with two smaller poles one to each side. Currently to the left of the large pole, looking at the back of the starter, I have the yellow/ red wire on the left and the grey black opposite. Does anyone know if this is correct or where I may be able to find an online diagram? I have the clymer book, but recently divorced, moved, and can't seem to locate it. Any help is appreciated. I also did a search prior to posting on omc starter diagram, but there were no results. Thanks. Bill
