OMC stern drive problems!! Help!!!!
marino72
I have a 89 sunbird w/5.0 302 ford moter in it. OK this is what has been done. A marina has replaces the shift cables and has adjusted the shift linkage. The marina has told me that I should consider replacing or rebuilding the upper stern drive and they said was getting "tired". I have replace the lower gear unit last year. After this weekend I concluded that I need to do this now as it won't stay in gear under load. Can anyone confirm that my upper stern drive needs to be rebuilt. Also can you direct me on finding a complete rebuilt kit for this job. I alread own a Clymer book. Please help! thanks
tommays
Re: OMC stern drive problems!! Help!!!!
wel thats not good because the parts that keep it in gear are in the lower gear case 32,33,38<br /><br /><br />
<br /><br />tommays
dolphins7272
HMMMM... the lower gear case is new. I have a problem putting the boat into drive. If i push on the shifting linkage it will engage. If I don't help it to engage it clutters and eventally it will go. Could this still be the problem? thanks for the help
olbuddyjack
I think a marina needs to double check their work...It sounds like a bad or damaged cable.
KaGee
You may want to look here: http://www.funkopolis.com:8080/~stuart/cobra/ <br /><br />Your problem has nothing to do with the upper. It's probably started by an improperly adjusted shift cable. i hope you haven't hurt the lower gears and clutch dog.
dolphins7272
It has prolly damaged the clutch dog and the lower gears. The damage was prollly done do to the bad shift cable before replacing. Could you tell me what gears I should replace? again thanks for the help
olbuddyjack
Check tommays post above, 32,33,38
dolphins7272
Do i need to purchase the gear case seal kit? Just don't want to start the project with out having all my ducks lined up ;)
KaGee
Originally posted by dolphins7272:<br /> Do i need to purchase the gear case seal kit? Just don't want to start the project with out having all my ducks lined up ;)
Anytime you break open a gearcase you should ALWAYS plan on having a re-seal as part of the job. You have the drive apart anyway.
marino72
is there any special tools I should purchase? thanks again
KaGee
A manual would be a good start.
