natispotatis
- Joined
- Jun 29, 2012
- 25
Hello, I've been lurking for days, using much of the information already supplied on this forum. I still haven't figured out my issue. I have a 1985 OMC Stringer outdrive and the tilt just went out. I hear the solenoids clicking and have 12V to the motor. I pulled the motor (using several new cuss words) and bench tested it and it spun really well. It seemed to have lots of torque. I thought maybe I had a bad ground so I put it back in and got the same results. An OMC tech over the phone thought for sure that I just had a faulty motor that wasn't pushing enough. Like a dummy, I went ahead and purchased another motor off ebay, installed it and am in the same predicament. I hear it wanting to engage and the motor is clicking. I know it's not a wiring issue because I hooked up a jumper pack directly to the installed motor. It randomly worked for a second or two when I was trying to diagnose it. That's it. I can move the outdrive up and down with some force and have always been able to. Can someone help me? I'm losing my mind! I hear it can be a hammer blow coupling perhaps. How do I get this out and how do I know if it's bad? Can I take the tilt clutch out of the housing, run the motor and see if the worm gear moves? I'm somewhat mechanically inclined but am new to boats. What are some things I can do to further diagnose the issue? I'm leaning towards a busted hammer-blow coupler (based on other threads) but am clueless on what to do here. Help!!! Much apprecieated!
