metalwizard
Thread starter- Joined
- Sep 13, 2010
- 411
Ok I did a search and did not come up with the answer I wanted.
I have a 1976 omc 165 HO (straight 6 chevy) with a stringer outdrive (electric shift) My temp gauge does not seem to work. either that or its running WAY cold.
I would like to put an aftermarket gauge in to match the Tach and Fuel gauge i added. so my question is. where is the temp ending unit? I am new to boating so I am wondering if the temp sensor would be on the engine in a cooling jacket just like a car, or is it something that is in the outdrive?
Once I get that figured out, what temp should I be running at while cruising? and when do I worry my temp is to high? basically whats normal? whats not?
Thanks
Thanks
