OMC Throttle control
trmelvin
I have a 1986 Baja Islander. Can you rev the engine without putting the drive in gear? I know there is a button on my merc for that put cant find one on my OMC? Any help will be appreciated.
LAC_STS
Re: OMC Throttle control
Yes there should be a neutral throttle button.
trmelvin
Is that going to be on the shift control? Thanks I'm going out to have another look
Don S
If you can't find a button, put the lever in neutral and see if the handle will pull out away from the control about 1/2" if it does, move the lever forward, that should be throttle only.
There are so many different controls on the market, that without a picture of what you have, it's impossible to give you an exact answer of how to get to throttle only.
Older boats are even worse. You have no way of knowing it the control was replaced or not.
chriscraft254
This is the kind that came with my omc. Like said, you pull the handle outward in neutral, then you can revve the rmps in neutral.
LAC_STS
My original OMC control operated the same way Don describes.
My new OMC/BRP control has a button in the middle/bottom of the control.
Id bet you have the kind Don talks about. If you cant figure it out post some pics.
Lou C
omc throttle control.jpgThe original OMC controls had a chrome handle with a black insert that said "OMC" on it, those did not have a button but you just pulled it out to disengage the shift system. They were actually pretty well made controls, mine still works fine after 24 years....
The one in the pic was used on Cobras, if yours looks like that it probably has no button and just pulls out.
LAC_STS
Yes sir!
Thats the original one I had.
The newer BRP replacements have the button.
bruceb58
Many different controls were put on boats with OMC Cobras. There were many from different manufacturers that were compatible.
