chillenthemost
Thread starter- Joined
- Mar 7, 2010
- 10
Ok I have a bizarre problem that I'm trying to trouble shoot. I have a 1985 stringer 3.0 OMC that will not tilt down. I have gone all through the wiring, switch, solenoid, etc. I put a new tilt motor on it because it had the original and I thought it was bad. When the motor is off I can hit the switch and the motor turns strong in both directions. Before the problem was permanent the drive would sometimes fail to tilt down but would always come back up strong with no problems. I'm thinking that I may have sheared the pin on the worm gear shaft. When I hit switch on the motor both directions I can hear the coupler load both ways. If any one has any suggestions on where to start it would be greatly appreciated.
