I am reading Stuart's article on adjusting OMC's shifting linkage. It says, "Remove outdrive, replace the transom bracket shift cable if outer jacket is ribbed. Use the appropriate service manual." I don't know what "If outer jacket is ribbed" means. What is the outer jacket? My cable looks like this:<br /><br />
<br /><br />Do I need to replace the cable? I'm asking all this because I have had a lot of gear grinding and thumping going into reverse on my 89 OMC 4.3. Once I finish all my other problems/projects, I plan on completing Stuart's adjustment.
