krustyCrab
Thread starter- Joined
- Jul 1, 2014
- 27
Greetings everyone... I am currently in the process of going through a boat i just purchased. I figured I would start at the engine and work my way back... I can honestly say im putting off working on my stringer drive but hey, its my first boat so I didnt know any better when I bought it... Fail me. At any rate I was able to get the engine started and tuned!!! My next step is getting the trim/tilt motors working.
Looking at just the tilt... I traced the blue and green wires from the tilt motor to the solenoids, I then traced from the solenoids to the switch. When I hit the switch down I hear a click (from solenoid) also a test light indicates good power to the tilt motor when the switch is down. Up does not make any sounds nor do i draw any power to the tilt motor. Im thinking that my down solenoid is good and the up is bad... I also think the tilt motor is gone which I fully expected to have to replace. Would you all concur that my reasoning is accurate about the motor and solenoids...
The primary question is can I replace the trim/tilt solenoids (982187) with any 12v 3 post solenoid? I can order the exact one and wait a few days, but im about as impatient as it comes so if i can get a suitable replacement from say Napa or some auto parts store I would prefer to do that.
Now onto the trim motor, this appears to be a hydraulic pump to the two rams on the front of the engine. I traced all wires back to solenoids and switch... I get no power to the motor when hitting the switch in either direction. Im assuming this means my solenoids are bad...
The interesting thing is I do have power to the solenoid cross bar...
Thank You for taking the time to read this...
86 OMC 4.3l v6 Stringer drive YAY
