Onboard charger question
AZcamperguy
If a 3 bank on board charger states that it handles both the wet and the sealed batteries can I charge multiple types on it?
What I mean, is if I have a sealed battery and two lead acid batteries can I hook them up to the three bank charger or do I need to have all the same type? Also, can I hook up 1 sealed and 1 lead acid to run a 24 volt trolling motor or do those both need to be the same type?
Fireman431
Re: Onboard charger question
You can charge both batteries on your 3 bank charger. I would imagine that you can hook the 2 types together, but I have never tried it. If not, someone will be along to correct me.
bullgator99
My Xantrex manual says all batteries in my 3 banks have to be the same type. Check your manual.
