1998 4.3 L Mercruiser raw water cooled. Brand new OEM manifolds and risers. Starboard riser is to hot to touch after as little as 15 min. run time. Port side is cool. Old starboard riser was warmer than port but not to hot to touch. Outside of manifolds on booth sides are cool starboard is slightly warmer. Checked water flow into bottom of both manifolds seems to flow about egual maybe starboard is slightly less.New water pump both in the outdrive ( Alpha 1) and circulating pump on engine and thermostat. Engine temp sits at 160.
Thoughts anyone
Thoughts anyone
