One of these things is not like the other...
StickyWidget
Below are pics of the two tires on my boat trailer, in one there is a part missing that the grease goes in. What is the part that is missing called?
nlain
Re: One of these things is not like the other...
Bearing Buddy is the common name for that part, although it does not really look like a bearing buddy. They usually have a spring loaded plate that has the grease fitting in it and you put just enough grease in it to keep pressure on the hub. You definitely need to pull that hub, clean and inspect the bearings for damage then repack, reinstall with new seal and bearing buddy.
batman99
Agree. Simple grease cap?.
roscoe
Looks like they both need more than a cap, a bearing buddy, or a cover.
THey need maintenance.
kenmyfam
Agree. Time to give them a service.
bassman284
Looks more like E-Z Lube hubs to me. Google E-Z Lube and get some info on them.
theBrownskull
They look like "Kodiak Red Eye" style hubs.
