One Person launching and loading boat?
heyyou325
Re: One Person launching and loading boat?
I didn't see waders listed for putting it back on the trailer. A good pair of either hip or chest waders, starting $38 something at Cabella's on sale a lot of times, will keep you dry. I back down in the water (just so it will barely float), have a rope with a small loop in one end and a snap hook in the other, put the loop around one of the cleats, tie the other end, or fasten loosely to the dock (some docks have eye bolts to fasten to), unhook from the winch and drive away. When you load it, tie it to the dock, same manner as above, back into the water, if you have a long cable on your winch you can just run it out and hook it in your front eye bolt, and winch it in. I have 50 ft of 3/8 cable coated in plastic in my winch. If you don't have a long cable have, an extra rope attache it to the eye bolt, and pull it to where your winch line will hook up. Hold the boat firmly while changing lines. Keep tied to the dock until it is on or mostly on the trailer. I find a manual winch will alert you easier (it winches harder) if you are going off center. The waders come in real handy for loading the boat, unless you like wet feet, pants, shirt, wallet, you get the idea. Remember the hole in the top leaks real fast tho. Just as fast alone as with someone else, as they are usually just standing around or trying to do it differently and mess you up. Good luck and good boating, probably fishing going alone, catch one for me the Game Warden might not count it that way. yea right.
Dolfan0925
This forum could use an entire section just for new people. I would have LOVED to have read this thread when I got my boat. Do pretty much the same thing, but had to reinvent the wheel by myself.
Baytown.boy
I back down the ramp to waters edge, take off hook of bow eye of my boat, then reach on the front deck for my 30' rope with a snap hook on it, hook it on the boat bow eye. Then coil the rope and drop it below the winch stand on the trailer, then tie the loose end to the winch stand. So when you back up you will not run over it. Back down real slow and let the boat slide off. When the boat is off the trailer completly, pull back up the ramp real slow again. Get out and finish pulling the boat back to the ramp or to the side and tie off.
When loading, I back the trailer down to where the bunk boards are about 1 foot under water. I take the 30 rope and hook out of the bow eye, and roll up and put back on the front deck for the next unloading. Then drive boat up on straight and drive all the way to the boy eye, hook and get out of my boat. I have built a cat walk on the front of my trailer for easy boarding and unboarding. Winch up tight and I'm ready to roll. I have installed side guide boards and pole lights for makes for easy loading, and backing down safely.
P.S. ONE GOLDEN RULE I HAVE, I DO NOT LET ANYONE ELSE HELP ME, BECAUSE I HAVE BEEN DOING IT FOR SO LONG, I DON'T WANT SOME ELSE TO GET HURT OR TO BE BLAMED FOR SOME ACCIDENT. When some else goes they back my truck with me in the boat and I just drive the boat off or on.
I have also installed plastic runners on my bunks that make things a lot easier for unloading and loading.
Home Cookin'
I think that if you have to get in the water, other than at most in knee boots, you are doing it wrong. Just because some people don't mind getting wet in hot weather, the boating process should be the same everywhere, including in cold weather. I have never seen anyone (intentionally) get in the water to launch or retrieve a boat, other than the teenagers with small sailboats and they are doing it that way for fun. But then again, I am around experienced boaters.
Use rollers so you don't have to back in so deep. Use a power winch. While the concept of floating on and off seems simplest, it can be easier to keep a boat straight when it comes up on rollers. I've been launching and retrieving boats SOLO up to 19' for almost 40 years, and a 21' for two.
Andy'sDelight
The ramp plays a part in it. The ramp I typically launched at last year required a slight brake tap to get the boat to slide back off the rollers. My boat was 21' and I used to tie a rope from the bow to the stem on the trailer, give it the brake tape it needed to get the boat to come off, then pull it back with the rope and climb on over the stern. Sounds alot more complicated than it was but thankfully my new boat is in a slip and I don't have to deal with ramp antics anymore.
Baytown.boy
Yes, no to waders, hip boots, etc. we fish year round here on the Gulf Coast, so not needed, not wanted. Practice is the best way. Put solid plastic, pvc, nylon, teflon strips on your bunk boards and it really makes a difference.
fat fanny
I nthe rigging area have all your lines and mouring bouy's on and ready back her down into water til she starts to float walk the traler tongue board her over the bow drop the drive and or o/b fire her up reach over the bow wind the winch relaease the safety chain wind the strap out far enough to un-hook back her off the trailer dock her tie off. load the admiral and kids and park the truck and trailer ten go boating all without getting wet with in 5 minutes. Just reverse the process when done for the day. All done by my self because the admiral is a spectator by nature but she is pretty good at watching the boat while I park the truck and trailer. Oh yea the real contributing factor to this technique is finding the sweet spot for you trailer in the water to make the boat just lift slightly off the bunks.
Blake0912
I just back the boat all the way down until it is floating with the wench still hooked up. Stand on the trailer so i don't get my feet wet, climb in the bow go start the engine then reach over the bow release the wench ( be careful not to let the wench hit you in the face while the boat slips down) when the boat slides down i grab a hold of one of my running boards so i can unhook the hook from the bow eye. Go dock the boat then go park the truck. To load i just back the trailer down till the water is right above the wheel wells and drive the boat up with the engine and its pretty much stuck to the trailer then, climb out stand on the trailer hook up the wench and climb down to the ground. I find thats the easy way no ropes or anything involved.
But when im at the beach house i have an easy solo launch solution.. its in a boat lift already, so i just hit a switch =)
Silverbullet555
Most of the time I launch and retrieve solo.
When I get to the ramp I pull to the side and put fenders on, turn on blower, pull transom straps, dock lines, etc.
Back in and float the boat. Pull it off and tie it up leaving enough room for someone else.
Drive the truck and park, run down and get out of the way.
On way back in, dock it and go get the trailer.
Usually have to wait a bit so I can back the trailer next to the ramp.
Walk the boat on and winch it up. Pull out and do the rest of the cleanup up top.
takirb
I learned to launch/retrieve by myself on a 22' pontoon. I almost always got in the water to launch it 'cause i refused to back down enough for it to float. When i was first taught how to launch it, my father in law backed my truck in where the bottom of the tailgate was under water, even the bottom of my truck's brake lights were under the water too, i was not happy. He said that's how you do it, but i'd rather just get in thigh-deep and shove it off the trailer instead (only took it out in summer season). I don't like the thought or sound of my truck exhaust gurgling under water, nor my brake lights being completely submerged, so i'd only back down enough to get half the back tires wet regardless. If it was a ramp that would allow it to float only backing down that much, cool, but if not (ramp i used most didn't), i had on swimming shorts anyways so it didn't matter. I'd unlock the winch strap, step off the trailer into the water, give it a good heave and jump aboard. Took about 10-15 secs from stepping outta the truck to the boat clearing the trailer on the water. Loading it was easier as i used the winch, and never had issues riding it onto the trailer unless it was really windy.
My 18' fish and ski is a breeze to launch/load solo, and i can do it faster w/o someone helping me. i don't have to get wet launching this one, i do the same as others have posted above. I've yet to encounter a ramp that didn't allow it to float by just getting the rear tires half wet, and even then sometimes i've backed too far. Maybe it helps i have a different truck now too ;) Might sound weird, but i look forward to launching/loading my current boat solo, guess i feel i've accomplished something since i used to be so nervous about it at first.
Engine344
I launch on a river.....Whole different thread LOL Tricky to do by yourself, but with time, practice and some luck works out pretty good......rarely can I load at idle. Good discussion though!
Blake0912
i can dunk my whole trailer in the water before the water would even come close to my tail pipe but i have a 4x4 truck with bigger tires and my trailer ball is on a drop hitch. Plus i guess im lucky with all the ramps that i use are not very steep. but i launch my 13 whaler/18 fish and ski/ and 22 bay boat the same way with not getting me or my truck wet.
veritas honus
I realize this thread has been around for a couple years, but THANKS for the great advice. I've been using waders or getting wet, but tried out the techniques listed and was able to launch and recover without getting in the water tonight, and was on and off the ramp in much less time. Thanks!!
Welcome aboard!!!
It's an old post, but this is exactly why no posts are deleted due to age. They're usefulness doesn't go away or spoil;).
This forum is a wealth of great information just waiting to be tapped into...
Welcome!!!
DaNinja
I thought there was a newer, bigger thread about this, but....
I back into the ramp and stop short of the water.
Truck parked and E-brake applied, I jump out and recheck the plug and pull the drive guards.
I then back the boat until it starts to float.
Truck parked again and I jump in and start the boat. (It was already run on the muffs, but I've learned after retrieving the wife in a dead boat floating around the marina)
Boat is running. Disconnect the bowline and back off and tie up to the dock.
Walk from the dock to the truck and park the truck and trailer.
Retrieval is pretty much just the reverse.
jonnymarquis
yes i know its an old thread but still good for the new boaters. here is how i launch. works well for me. and this is a video so its better then words.
http://www.youtube.com/watch?v=i1N27s9O3Mw
and for loading i tie the boat to the dock, go get truck and trailer back down into water. then i get back onto boat, drive it onto trailer, cut off the motor, and hook up the winch line. then this is where it gets interesting. the tongue on the trailer is not to long so my exhaust is almost in the water. so if its cold like it has been, lol, i crawl threw the back hatch of my explorer and into the seat and drive out. if it warm then i get my legs wet. lol, i don't care who is watching from the shore. at least I'm pulling a boat from the water.;).
linxlvr
I'd say that really is situational. I've been to lakes where the front tires got wet. Some of the places around here really shouldn't be called ramps at all. add to that, electric only, and of course mine is a bow mount. Not saying your wrong, because I've been outsmarted quite a few times, but I've run into a number of situations where simply donning water gear was the easiest thing I could come up with. And the person before and after me. :)
dw
DaNinja
You may have to adjust your procedure for a boat coated in Vaseline.
infideltarget
The addition of Vaseline can cause changes to MANY procedures.
My favorite way to launch solo, is to go to a ramp upstream, push the boat off, and try to get to the downstream ramp and park before the boat drifts past the dock. Retrieval is a problem though, because when I get out of the boat upstream, I cant seem to run fast enough back down stream to get the trailer backed in quickly enough to snag the boat as it drifts past. Maybe I should refine my technique, and drop off a moped when I drop the boat upstream. Hmmm....
444
My 15' glastron gt-150 is no problem to launch/retrieve solo. It's got the easy loader trailer that's all rollers so I find it easiest to keep the trailer just a little further out of the water and hand winch it up/down the rollers. If I dunk the whole trailer in the water, the rollers can't keep the boat straight as I winch it up. If all your trailer has is the carpeted bunks, then you have to dunk the trailer and float the boat a bit. The hardest part in that situation is retrieval because you don't have that second person to line the boat up as you pull the trailer out of the water. I think the key is really having the trailer at just the right distance under water.
oops!
im gonna chime in on this old thread....
i use the float on float off method....
i can launch a 25 footer by myself in under 90 seconds with out getting my feet wet.
the trick is backing the boat in as close to the dock as possible.
with the safety chain attached and so is the winch....back in till it floats with the bow still on the bunks......jump in the boat via the bumper......and un do the chains and winch.....climb aboard.....and push off to the dock......tie up and drive the truck out.
loading is the reverse....
i never power load.....it causes the loss of props and other dangers.....
