maryhannaj
- Joined
- Sep 22, 2013
- 422
I figured I would start a new thread for this issue. I have a 1982 115 hp Johnson. When i run the motor on muffs and then pull the plugs, The starboard bank cylinders are running leaner than the port side bank.
I understand the jetting process and the way the carbs work, so why would the cylinders on one side running off of two seperate carbs and two seperate barrels be consistantly leaner than the other side all together.
The side that is leaner is still what I would consider a good safe tan color so maybe the other side is running too rich. To me this is pretty confusing because I dont know which side is right. Either way, one bank is different than the other and while examining the inside of the combustion chamber with a flashlight, even one of the piston surfaces on the leaner side appears dryer than the other. As usual, I could definatly use some input from anyone willing to help or has experienced this issue as well. Thank you all!
