One Soft Spot
I'm new to boating so please excuse me with the Newbie questions I took my boat in for service today and had the transom inspected they say it is Rock Solid so I'm hoping for the best I'm going to work on it this weekend and start cutting some wood open I bought some carpet to replace it with I'm going to see what I'm working with if anything I can get a season or two out of this boat and then I will toss the engine and outdrive into a boat with no engine.
make a few test drills
if your boat only has a soft spot in the deck, call Guiness to make it to the book of world records as yours will be the only one ever.
JASinIL2006
If you have to cut the carpet to fix the soft spot, you most likely will have to pull some/all of it up; I don't think you can cut out a patch and replace it, without it looking like heck and fraying. Assuming you have to replace some of the carpet, cut a hole in the deck larger than the soft spot with a circular saw set for 1/2". If that doesn't cut thru it, increase the depth by 1/8" and repeat until you cut deep enough to get thru the decking material.
Then pry up the piece, and inspect the foam and any structure below. You most likely will need to cut out some foam - it's probably wet and/or compromised anyway from whatever has been causing the soft spot. As you remove foam, you should expose one or more stringers or bulkheads. Drill a 1/4" into those about 1" from the hull. (You also should do this on the sides of the motor mounts and along the walls of a ski locker, if you have one. Those ski locker walls are usually stringers.)
If the shavings come out dry and light colored, fill the holes with 3m 5200 sealant, get some Great Stuff foam to fill the hole and patch your deck. Then go buy your lottery ticket.
If the shavings come out wet and/or dark, you have structural issues that will need to be explored further.
None of us are saying this to be mean or gloomy. Many of us have been in your shoes: we found a problem, looked for ways to deny it was as bad as we feared, but eventually we learned that our boats had problems. If often starts with one soft spot or a screw that turns and doesn't seem to bite into wood anymore. It would be great if you don't find yourself in that position. But it would also be a little surprising...
Good luck and let us know what you find.
Blasanch92
Ripped up the wood And the stringers are rock solid so solid that I tried even took a hammer to one didn't budge at all just curious how some of you can automatically assume that someone stringers are rotten based off a post and demand they are, Wheres my $100 it almost looks like they were replaced before but the deck wood isn't even a 1/2 inch no fiberglass whoever replaced it did a horrible job.
JASinIL2006
Sound promising, but knocking won't tell you anything. You need to drill into the stringer, about 1" from the hull. The knock test is deceiving.
your boat received a deck over. do the drill test and post pictures to prove the results.
My 1979 model WELLCRAFT was nothing but dust / plywood flakes ( beaver puke ) in the transom and stringers.-----And that was discovered in 1994 so after 15 years.
Woodonglass
I bought some Great Looking apples one time. Nice an solid. Really Looked great. Got home and cut one open and WHOA. Worms!!!! Ya just never can tell what's inside unless you Open it up and take a good look!
chevymaher
LOL WOG remember mine actually had a worm in the stringer. I had zero soft spots in my deck. I hammer tested it passed. Sure failed when I did what was suggested. They rot in the back and lower transom. All the wood in the bow of mine was solid.
I remember cutting thropugh the glass in the transom. Water ran a while.
Blasanch92
Thanks for the people who actually tried to help as for the rude people who just came on here to be a douche and troll go find something better to do I appreciate the people who actually tried to help the Stringers are solid at least the few that I can see I'm going to replace the deck in the open bow and use the boat for a year or two and then upgrade to a better boat I don't really care to redo the whole deck and stringers because it's not worth it for a boat that's worth maybe 1500 dollars thank you for everybody who helped you can go ahead and lock the thread.
GA_Boater
We don't lock threads when given advice doesn't tell what you want to hear. All the rude posts, in your opinion, are based on real life experience. No one came here to be a douche, except maybe......................
Blasanch92
You haven't seen my boat there for you do not know what's wrong with it I could care less about your personal opinions of my boat when you haven't even seen it I'm the one who cut open my deck I'm the one who saw my stringers and tested them I'm the one who's replacing the wood I could care less what some of the people here trolling have to say I'm the one who's here looking at my boat my question has been answered therefore I don't need any more of your sarcasm why would I rip out a whole deck and stringers for a boat that I'm using for one season makes no sense I'm not spending more money in a deck then I did for the boat itself get that through your thick skull I'm only using the boat for a year than buying a new one this is to give me practice with proper boat driving I will simply fix the rotted wood and go about my day because I have inspected the stringers that I can get to and they are solid as a rock I appreciate the people who treated me with respect and gave me legitimate advice that I can use.
GA_Boater
Respect works two ways. Get that through your thick skull if I may use your words.
I suggest you just ask questions and ignore what you don't like. Just say thanks and move on. This isn't the place to pick a fight.
sphelps
No one is trolling here .. Heck I don’t even know what a troll is ! LOL!
And your right .. You are the only one who has seen or inspected the structure . If you had posted pictures of everything as you went then we could have seen what you see .. Who knows everyone’s opinion might be the same as yours ..
But we can only go with the info given .. Sometimes you may not like what you hear .
I hope for you and whoever rides in your boat that everyone here was completely wrong and your boat is in at 1% of the restorations that post here and are ok structurally ..
Regards ...
rothfm
Ensign
Blasanch92: IF this is still active, I'll lighten the tone a bit....While I do agree with most of the points in this thread, I'll toss in a tad of perspective.
Like all others here, I too have had many 16-19' boats with the occasion soft floor/Deck. Not the end of the world, providing you conform the transom and stringers are decent.
Been boating all my life, and have torn up many floors in the bow, and cockpit area. Weekend job. Yea its messy. Maybe you have to de-foam. Maybe replace and glass some stringers. But Not all soft floors are total Junk. Reasonable repairs can be made.
Done the exact above and enjoyed the boat for years afterward. Just really depends on the situation/boat in reality, and your skills to literlally "Dig-in". Yes, some are beyond repair and the owner has to come to terms with that.
Good luck.
Woodonglass
It never ceases to amaze me when a NEW boater, never owned one and Knows NOTHING about their construction etc. comes on a Repair Forum and asks for help and then SCREAMS at the experienced members telling them they are douche bags because HE KNOWS BETTER. If that's the case then why do they come here and ask questions. Maybe its' just me cuz everybody KNOWS that I AM just and Old Dumb Okie!!!
roffey
I think his problem was, he reported a soft spot and most here said he "must" to do a complete redo, no if and or buts about it. Im not saying he does or does not. I think its difficult to tell from a description never having seen the boat.
Before I get flamed for the comment I do agree if you don't want an answer then don't ask in the first place. I'll fade back into the background now, lol.
Spring is just around the corner, yea....
