Dukemeister
Thread starter- Joined
- Jul 26, 2013
- 27
My 1992 5.7L Mercruiser has stated up after a long lay up! It starts but won't idle unless throttle is advanced about 1/4 can get it to idle but it surges between 1000 -1500 rpm and stalls if I go under that range. My "best guess" is I need a carb kit (floats/etc), but could it also be ignition? I carefully sprayed some carb cleaner in it while running and it ran smoothly while being injected with the cleaner... leading me to believe the surging is fuel related rather than ignition related... but I'm not at all knowledgeable/experienced on these things.
I still am trying to find out what carb I have so i can get the right rebuild kit. Here are some photos. Also form the S/N etc can you tell
1. what is the rated HP? The transom has a big marking WARNING 230 HP max... is this a 230 HP motor?
2. What version Thunderbolt ignition is on this?
Thanks! Duke
Thanks! Duke
