one white spark plug ? evinrude 90hp 1986
Bearded Lady
One out of four of my plugs is white and burned. What could be causing this. top right looking at it from the rear of engine. The motor runs great but doesn't idle well.
ob
Re: one white spark plug ? evinrude 90hp 1986
Possibly a fouled carburetor.Run a compression test and see if that cylinder is lower than the others.
rodbolt
most likely its a scorched piston now. do a compression test before anything else.<br /> poor idle is a sign of a bad hole and with a burnt looking plug it was hot inside the cyl.
