Re: Only one gear oil plug????
Tim Frank - Thanks this is the closest i think i've gotten to finding out where the engine comes from
Details on the transom plate are.....
"Model number is BM 140 A
Year 1996
Serial number G 04178749" Thats it
Engine is a 4 cylinder 2 stroke and seems same as BJ130TLEDM from what i can see.
I've been looking in the area marked by your yellow circles. No bolt in the bottom circle and no obvious fill / cover either!
OK, the bottom circle is about where the drain plug should be.
When i first looked at your pic I was sure that there was a plug head there....but i just enlarged the image and it is shadow and illusion...:redface:
I "
think" the plugs are magnetic and the housing is cast Al. So you might try "fishing" for the plug with a small and powerful magnet. It might have just been covered with Bondo or fairing compound for some unknown reason.
As has been said, there WAS a drain hole there when it was made!
