Capt dave 258
- Joined
- Jul 14, 2021
- 92
Have a Mercruiser 4.3 ltr, 1995. Recently purchased, clean boat. Carbureted, electronic ignition. Had it on the lake and was running great. Trailered it home during a severe rainstorm and got lots of rain and moisture in the engine compartment. Went to the launch a few days later and it'll only run in the crank position. The moment you let the key go, it dies out. I believe it's an ignition problem but not sure. Getting gas during initial cranking. I thought I remember that once you let go of the key, the electronic fuel pump stops its initial primer phase and goes into a low pressure phase that may run through a diode or transistor that's in line with the wiring?? My mechanic says that it should still run for a few seconds off of the gas that's in the bowl. He had me check the purple wire from the positive side of the coil when it's unattached and see what the voltage is. I did so and it's .05 volts, which I assume is nowhere close to the 12 volts it should be?? I'm waiting to hear back from my mechanic but thought in the meantime I'd get help/ideas from this post. Thanks for any input.
