Open-air spark tester arc length for Johnson 85hp 1974?
kippstakes
Getting ready to test compression and spark on my new, used, engine tomorrow. How far should the arc be able to jump on an open-air tester?
Thanks
kbait
I've always tested by the following:
Points ignition - 1/4" snappy blue spark. CD (electronic ignition) - 3/8" in open air.
Both ignition types will likely arc more than that, but those distances will be adequate for proper spark across the plug gap under compression.
Good luck!
