hwsiii
Thread starter- Joined
- Jan 25, 2009
- 2,639
I want to apologize to you specifically 45Auto for our discussion and some of my statements about maximum speeds attained using higher pitched props for attaining fuel economy while cruising. I am not positive that increasing pitch always results in better fuel economy while cruising with all props, as part of what is happening is that you are moving the RPM scale available from an engine from a higher RPM available to a lower RPM available from that same engine, so you will definitely see an increase in MPH available at any particular RPM setting and a commensurate amount of excess load applied to the engine the lower the maximum RPM falls. But your statement that any particular speed requires X amount of horsepower and that the more open the throttle is the more efficient the engine becomes DOES explain that, and I have to take that as the gospel, and I am sure that you are right. I do believe that it requires a search for the right prop using a GPS, tach and a fuel flow meter to ascertain which prop is better for fuel economy at cruising, and exactly what RPM the best fuel economy is attained with that prop.
What I was surprised by though, was that even though my numbers are right when using a 10% slip rate, they are NOT realistic in the real world, because of differences in prop slip and many other factors, and I have to thank you 45Auto for making me go back and run many new analysis of my numbers and the basis for why they do or don?t work. Since then I have spent a lot of time learning more about motors and fluid dynamics, and have learned more than I knew before, I hope in a year or more to better understand fluid flows, although at this time I am definitely a neophyte.
I also want to apologize to everyone else on here that has used my formula for increasing pitch size and the amount of expected changes in RPM. From doing an analysis of many different SS props that are the same make and model but different pitches on the same exact boat and motor I have found that my formulas do not consistently reflect the actual RPM change that I expected. I have found the problem to be that manufacturers do not always predict the PITCH and other changes that there props have correctly, even in the same manufacturer, make and series of prop. So I am at this time trying to find a better formula to represent these changes, although it will NEVER be EXACT, hopefully it will better represent the differences to be expected in general.
I am consistently trying to search for the truth about boats, motors and props, and to try and find ways to simplify our understanding and what an be expected when we change propellers. I have found that mathematics helps me have a better understanding and be able to replicate better what should be expected with certain changes made to a new prop. BUT it is NOT mathematically possible to find the EXACT best prop for any boat and motor, that requires knowledge and experience even to find a BETTER prop for any boat.
I hope everyone accepts my apology for giving them BAD information, I try the best I can to only give everyone good information here, and I also will try to do so in the future. If I find that I have given bad information, I will do the best I can to rectify that and let everyone know as soon as possible.
H
H
