e2firefighter
- Joined
- Aug 25, 2012
- 11
Ok, here goes...... I have a 1995 Harris Kayot Ultracat equipped with a 350 magnum. The boat is in excellant shape and everything works except for the temperature guage. I grounded out the wire coming from the sending unit and the guage maxed out. As it was explained to me, this tells me my guage and wiring are in working order? Ive also changed the thermostat (160) and sending unit. The guage still doesnt move above the bottom number which is 120. Even after running at WOT i can immediately touch the water from the exhaust, exhaust risors and thermostat housing and its barely hot. The water temperature here on the Ohio is around 80-85 degrees. My boat is running rich and i can here it missing between the 2200 to 3000 rpm range. Im beginning to think im not getting up to operating temp. Is that even possible? Any help would be appreciated.
