operating temperature of ignition coil?
hoot
was out today running for about 30 minutes, motor started missing. started trouble shooting. found ignition coil very hot, could not hold onto it. checked volts to + terminal. running had 11 volts, motor off & key on had 7 volts. boat would start and run up to 2500-3000 rpms but not any more. all other components seem ok, new plugs, points, condersor, filters. any suggestions of what could be the culprit are appreciated.
Scaaty
Re: operating temperature of ignition coil?
A hot coil (they do get hot by the way) might be caused by points not opening enough...I'd recheck your ignition again. Try a new set of points too...there cheap.
D
DJ
Guest
Your voltage readings seem backwards, to me.
11 volts running is a little high. It should be in the 9-10 range. You should have a ballast resitor in line that reduces voltage.
