SS MAYFLOAT
- Joined
- May 17, 2001
- 6,372
On my 27' I have just about finished with re-glassing the area where my fuel tank lays. First let me explain the secenerio. Under the fuel tank (which is 8' long) has 1/2" plywood. Next under the plywood are stringers that are about 8" on center and are only 2 1/2 inches high. So this leaves me with 8 spaces of dead air space that are 8'x6"x 2 1/2". At the ends of these spaces it is sealed off. This is the way the boat was manufactured. All other spaces have been filled with foam core except for these spaces under the fuel tank.<br /><br />So my question is this "Should I foam core these areas? With these areas being at the lowest part of the hull makes me leary of these areas eventually water logging the foam core. Then another opinion from a fellow boater suggested that at the ends of the spaces (which would be located in the bilge) to drill holes in each one of them and epoxy in a sleeve for a drain plug. Then after use, pull the plugs every once in a while to check for water leakage. This seems to be the way I wish to go. These 8 spaces each would work like water tite compartments. If I did get a puncture to one of them while it is in the water, at least the boat wouldn't sink. With the drain plugs being installed, it would then help me isolate which area has failed.<br />Thanks for any input..SSM
